Re: My Dad's 1970 220
Unread postby rcb on Tue Mar 26, 2013 10:13 am
While I know it's sold, is there a chance you could get some photos of the front suspension for reference? (assuming it hasn't been picked up)
rcb
Travco Model: Looking for 210
Unread postby Acesneights on Tue Mar 26, 2013 7:47 pm
What do you want pics of ? The Springs ? I have 2 other 220's as well.
Unread postby Acesneights on Tue Mar 26, 2013 7:54 pm
Well, I semi prepped it for the new owner. Bled the brakes and got a nice full pedal. My 7yr old did a great job as a pedalman.
I drained the gas, flushed the tank and put fresh gas in. Then the carb crapped out. it wouldn't idle. I was not happy. I pulled the jets and cleaned them and put it back. It ran even worse...Ughhhh...I did them again and viola. It's running good. Dang I hate gassers and forgot what a PIA carbruated engines are. Mine's getting a Cummins for sure... :mrgreen:
Unread postby rcb on Tue Mar 26, 2013 8:25 pm
Springs and the front axle setup.
2 more 220s?! You have quite the collection.
rcb
Unread postby Acesneights on Tue Mar 26, 2013 9:10 pm
yeah, not always a good thing...I rescued too many strays..I'm like one of those cat lady hoarders but with Travco's... :lol:
Unread postby rcb on Tue Mar 26, 2013 9:35 pm
:D
I was getting bad with motorcycle a year or so ago and finally cleaned house, though I still have two... for now :)
If I'm going to trouble you to take pics, could I also talk you into gettings a center of tire to center of tire measurement across the front.
...if I find a 68 210, I'll probably waste no time changing over to 8 lug... as it doesn't look like any of the 68 210s have 8 lug wheels. So in theory I'm trying to look at front axle swap candidates. Some of the newer cab and chassis have GVWR of 12,500 so their front axles can certainly handle it, not to mention newer brake assemblies.
rcb
Unread postby rcb on Tue Mar 26, 2013 10:44 pm
How is the wind in your 220's? This is certainly the largest vehicle I am considering... having seen more than a couple RV's blown over on the interstate in the northern part of the state. I'm not sure of the weight/size split. Would you say your 220s are more sensitive to the wind or about the same as your 270?
rcb
Unread postby Acesneights on Wed Mar 27, 2013 5:51 am
Actually because they are more areodynamic than even alot of newer high end rigs and combined with the weight they are very stable. The 220's handle much better being shorter. The 270's got that big ole butt hanging past the rear axles and the water tanks all the way in the back. The 270's with sway bays handle alot better than the ones without.
The 220 is very easy to drive. As a kid growing up my mother used to drive ours all the time.
Unread postby rcb on Wed Mar 27, 2013 6:56 am
That brings up a question I've been considering, did your family use the 220 for casual trips? Like to the zoo or local attractions? I am hoping to be able to multi-task some with whatever I get. I realize these things are big, but still. I've driven box trucks, which I'd bet are about 8' wide and longer than 20 feet. Would you say they are somewhat similar in traffic?
rcb
Unread postby 77Travco on Wed Mar 27, 2013 8:24 am
I have had my 270 on the road at 80mph several times now... seemed pretty stable to me. Driving around town is really not bad at all if you are comfortable driving a larger vehicle.
PreviousNext
Return to Travco 220
Users browsing this forum: Google [Bot] and 3 guests
