Rebuilding my 75 travco
Travco Model: 1975 travco
Re: Rebuilding my 75 travco
Unread post by Whitewhaletravco » Thu Jul 23, 2020 6:28 pm
Building utility box area.
Unread post by Whitewhaletravco » Thu Jul 23, 2020 6:29 pm
Airhandler installed, working on mounting the condenser
Unread post by Whitewhaletravco » Sat Aug 01, 2020 1:22 pm
I finally got into installing my mini split condenser in my new utility cabinet. The condenser swivels so I can access my ventless water heater that will be mounted on a wall, behind the condenser. Nokink makes stainless AC flexible tubing in 3 foot sections (or more then 3 if you require). That will give me the ability to swivel without bending any copper tubing. Here is where I’m at currently.
Unread post by Whitewhaletravco » Tue Aug 04, 2020 5:33 pm
Locking mech in place
Return to “Travco 270”
