download/file.php?mode=view&id=1778\nThere is no monitoring panel or anything that shows the tank levels and I haven't found a converter yet. The plugs work and the 110 circuits but haven't figured out the 12 volt system yet. Still looking for the 12 converter.
download/file.php?mode=view&id=1785\n\nSorry for all the separate posts it's the only way I know how to post pics. I hope to finish cleaning it out this weekend then figure out the 12volt system
- Travco Model: 270 1973
Ok, so its been a while but the cummins is in place together with the allison 6 speed 2100 mh. I used the original engine mounts that the 440 used but moved them Six inches back for better weight distribution and more clearance in the front. IT Will take some extra work to the floor area but I think it Will be worth it in the end.
Wow, looking good. That's gonna be one cool old coach with that Cummins swap.
