TRAVCO 270
TRAVCO 270
Unread post by Dave78Chieftain » Fri Apr 17, 2015 9:55 pm
Image\n\nImage\n\n960 Info\n\nImage\n\nImage\n\nImage\n\nImage
Re: TRAVCO 270
Unread post by 77Travco » Sat Apr 18, 2015 8:18 pm
Very cool... Thanks for posting!
Travco Model: 70's 210/220/270 aka none yet
Re: TRAVCO 270
Unread post by Psychowolff » Sun Jul 05, 2015 3:19 pm
Dave, Is the 960 info on your website? I'd like a cleaner copy of it that i can see and read all the smaller print.
Re: TRAVCO 270
Unread post by Dave78Chieftain » Mon Jul 06, 2015 5:23 pm
I grabbed these from the old MyTravco.com website. What you see is the best there is.\n\nDave
Re: TRAVCO 270
Unread post by Zugig » Tue Jul 21, 2015 8:59 am
Dave, I have a '67 270 that needs front wheel brake cylinders. I thought I once saw a table you put together that showed current part numbers that would be proper replacements for original OEM parts that can't be found. If so, where can I find that table?\nThanks
Re: TRAVCO 270
Unread post by Dave78Chieftain » Tue Jul 21, 2015 8:22 pm
I am fairly sure the 60's era used a P300 or P400 Dodge Forward Control chassis.\n\nIf you can, check the Dodge chassis VSN number to see which chassis you have.\n\nCentrix lists brake parts for the 66-67 P300 chassis (light/medium duty chassis)\n\nRaybestos lists brake parts for the 66-67 P400 chassis (medium duty chassis).\n\nI do show 71 P300 brake parts at the bottom of my 1969-71 Dodge Class A M300 (Early) Motorhome Brakes webpage.\nThat data does come from the Centrix and Raybestos websites above for 1971.
