Travco 270 Motor Mount replacement
Unread post by Acesneights » Tue May 12, 2015 7:49 pm
So I did my motor mounts. Easiest Mounts I have ever changed. I think it took me 30 mins with hand tools. I won't go into the nut and bolt work of the mount itself. That is self explanatory. 3 bolts. For 40 yr old original mounts, the nuts came right off like they were brand new. It's tight on the two 3/8 studs. I used a flex head ratchet and some patience. Jacking the motor up is really the hardest part.\nNow every Travco maybe a little different so don't take my method as gospel but I was able to do them without removing the engine fan. it will take two people. I used a simple floor jack under the oil pan with a flat block of wood between the jack and the oil pan. Make sure you don't have the wood against the drain plug or you could bend the oil pan. I had someone jack the motor slowly while I was inside and guided the fan blades past the shroud by gently pulling on them while pushing in on the shroud. I did not bend the fan blades. Did one side at a time. The part number NAPA 602-1115 is the correct number. They were only 4$ each... :o :mrgreen: \nMy old mounts were pretty wasted.
Re: Travco 270 Motor Mount replacement
Unread post by 77Travco » Tue May 12, 2015 8:57 pm
How many miles are on your coach? I guess I need to check mine.
Unread post by KB2CRK » Wed May 13, 2015 11:51 am
Glad to hear they are that easy. I switched over to electric fans so I could do it by myself if that was the only reason for the second person. Time to order the NAPA mounts now that the number is confirmed.
Unread post by Acesneights » Fri May 15, 2015 6:41 pm
77Travco wrote:How many miles are on your coach? I guess I need to check mine.
\n101k but I think age is more the issue than miles.
