seats
- Travco Model: 1972 270
seats
Hi\n\nDoes anyone know what the base for these seats are made out of? (i stole a pic from inside Nessie, hope its ok \n\n
\n\nIs it wood or is it steel?You do not have the required permissions to view the files attached to this post.
Re: seats
The base is made of plywood with steel angle to mount to the floor. There is a thin layer of foam padding and the same type of material as on the seats wrapping them. No problem using the picture from Nessie. Nessie is a 76 and those seats are out of a 69 270. I replaced the original couch/bed with those dinette seats and turned the old rear dinette area into a bedroom only. Nessie was 30% gutted when we got her and we are working to set it up the way we like. Hopefully it will look a little like a Scottish Pub when we are finished.
Re: seats
Thank you for your answer.\n\nI need to build the seats myself so I wonder if you know if theres drawings/measurements somewhere online?
Re: seats
Do you have the seats? I will try to get some measurements for you. I have to pull the seats back out to change the floor covering again. I will take pictures also. The seats are bolted through the plywood with capture nuts.
Re: seats
thank you very much!!!\n\nAnd no i dont have the seats.
Re: seats
With out the seats you might want to find seats locally and build the boxes to fit. If you find seats you may find bases with them.
Re: seats
I think I need to build them myself. Have tried to search the market here in Norway but that kind of seats are very very very hard to find.
Re: seats
Did you have the time to measure the base for me?
Re: seats
I have not measured them yet. I am not at home for a couple days. I will measure them when I get home on thursday.
Re: seats
Thank you very much sir!!!
