What chassis on my 1973 270?
- Travco Model: 1973 270
So I'm new to Travco's.\n\nI bought a 73 that I assume is a 270 since it is 26' and some change.\n\nAi know I will need some suspenion parts but the more research I do, the more confused on what chassis I have.\n\nAnyone have any ideas?
- Travco Model: 1967 Travco 270
Re: What chassis on my 1973 270?
Check this post for your answer:\nhttp://www.travcoforum.com/viewtopic.php?f=39&t=534
Thanks, I just found that.\n\nLooks like a M500 or RM400
Wasnt sure if these are in my library, so Imade a copy and thought if anyone\nhas trouble getting this nfo in its entirety... Here they are... Very informative...\nHTH\nBBB
Also keep in mind that your chassis may have been built a year before your coach was assembled on it.
If it has 17" tires it is a M375 with split rims\nIf it has 19.5" tires, it is a M500 (RM400)
