1972 Dodge Travco 270 - Hydrovac Rebuild
Hello Everyone,\nTook the Travco on her maiden voyage 150 miles to LA last weekend. She ran great! I ended up rebuilding both Hydrovacs with kits from Matt Sweeting's Speed shop. His # is 714-330-5286. They cost $40 each which is a great deal compared to a few I've seen out there. I have lots of pictures of the rebuild of the Hydrovacs if anyone needs them. The Shop Manual does a great job illustrating each part. It was way simpler then I thought it'd be. \nThanks for all the wisdom you guys share on here....I wouldn't have been able to get her home without you!!\nThanks again,\nSean
Re: 1972 Dodge Travco 270 - Hydrovac Rebuild
I will be more than happy to add any info (pictures, part info, descriptions) you have to my Hydrovac page which is based on the Dodge Service Manual.\n\nDave
