Power Converter issue?
Unread postby kingdome627 on Tue May 31, 2016 10:55 am
I ran a power cord to my 72 Dodge Travco to test out the air conditioner. The power worked fine before testing the AC. When I went to turn on the AC the box in the back under the bed started buzzing extremely loud. Then it was just humming and no power to the coach. I still don't have power and none of the switches on the fuse box were not tripped. I have attached a pic of the converter. Can I get a new one? Is there something I'm missing as far as a fuse or reset? Any help is greatly appreciated.
Thanks,
Sean
kingdome627
Re: Power Converter issue?
Unread postby 77Travco on Tue May 31, 2016 11:50 am
Looks like a transfer switch. My 77 model doesn't have one... I'm guessing that someone added that in? It should select genset power by default. When shore cord becomes energized, then it should switch over to shore power. Of course it could be set up differently.
My coach has a shore cord that either plugs into the genset or a 120V AC receptacle.
Unread postby kingdome627 on Thu Jun 02, 2016 10:41 am
Took a few more pictures off whats in my rig. Its a PD708 Progressive dynamics converter. Any suggestions for a replacement or know what that thing is attached to the wall is greatly appreciated.
Thanks,
Sean
kingdome627
Unread postby Acesneights on Thu Jun 02, 2016 7:55 pm
You have to watch what one you use. The Travcos were wired a little different than newer RV's. I can't for the life of me remember which one I used but it had the Charge wizard thingy on it.
Basically the Progressive Dynamics unit iirc has 2 circuits for the 12v house and then a circuit that charges the battery on those older units.
That funky looking panel on the wall looks like 240v a/c by the colors and kinda scary that it's exposed like that.
Most Travcos I have seen either just have a house power cord and then an outlet from the Genset to plug the house power into or some actually had a Service panel with a transfer switch(My 1970 220 had this). Never seen what you have but it looks very dangerous to me.
Unread postby Acesneights on Thu Jun 02, 2016 7:59 pm
When you say something was buzzing do you mean the power convertor ?
Also when you say you have no pwer now do you mean on the 12v side or 110 ?
Unread postby kingdome627 on Fri Jun 03, 2016 12:14 pm
It was the undentified thing buzzing. I have no 110v power or 12v power when plugged into shore power outlet ever since this happened.
kingdome627
Unread postby kingdome627 on Fri Jun 03, 2016 12:29 pm
It was the undentified thing buzzing. I have no 110v power or 12v power when plugged into the shore power outlet ever since this happened.
kingdome627
Unread postby 77Travco on Fri Jun 03, 2016 6:41 pm
Do you have a Wiggy or another 110/220 volt AC test meter? Sounds like the transfer looking switch in the picture has gotten hung up. This is an AC voltage issue not getting through that switch.
Unread postby PrivatePilot on Thu Apr 20, 2017 9:05 pm
It does indeed look like a transfer or relay of some sort to me as well. Post some closer up pictures please.
And yes, do be very careful - all those wires will be very much hot when the coach is plugged in, might be hot when your generator is running, etc. That's certainly not a very safe setup - once you get it sorted out you might be wise to put it in some sort of enclosure.
PrivatePilot
Technician
Technician
Return to Travco 270
