our 320
Re: our 320
6 lug rims where used on the M600 chassis. You really need to locate your Dodge VIN number so it can be decoded to understand what your base chassis is. The VIN number plate is in the front radiator access area (driver side wall) on my 78 Winnebago. Not sure if that is the typical place on a TRAVCO or not.\n\nDave
- Travco Model: 1977 m320
Re: our 320
There is a Vin tag there. I'll check it out. Thank you
- Travco Model: 320
Re: our 320
5-lug on 8" spread is stock in '76. Believe the rear end should be a Rockwell unit, not a Dana 70- somebody may know this for 100%
Re: our 320
New king pins and wheel bearing up front. All new tires, bearings and carrier out back. U joints in the driveline tomorrow. ........maybe a sweet test drive! \n\n\n.
Re: our 320
I wish that I had a garage big enough to park my Travco in!
- Travco Model: 320
Re: our 320
Me, too- I'd love to have my Travco nearby to work on. God only knows what it'd cost around here for a shop like that...
Re: our 320
I love my shop! My wife thinks I spend to much time out there...
\nI'll let you know how the test drive goes
Re: our 320
\nIf you have a minute post up the part numbers to the u joints, carrier bearing etc you used in case they are different from the 270.3rdranger wrote:New king pins and wheel bearing up front. All new tires, bearings and carrier out back. U joints in the driveline tomorrow. ........maybe a sweet test drive! \n\n\n.
Re: our 320
I did not replace the carrier bearings as they were in good shape. The u-joints were Neapco, part number 3-0056. To the beast for a drive tonight. Rear diff was nice and quiet. Front end felt much better!
Re: our 320
Same number as a 270. Ok good to know. I'd bet the 270 Bearing is the same too.
