Board index » Travco Motor Homes » Travco 320/350
travco parts
Unread postby 3rdranger on Mon May 11, 2015 11:30 pm
Hi all. We are starting to restore a good running M320. Looking for a screen door and oem gauges. Advice is always welcome too! Cant wait to get this beast going! Thank you!
3rdranger
Travco Model: 1977 m320
Re: travco parts
Unread postby Acesneights on Tue May 12, 2015 7:27 pm
Post some pics of your 320.. :mrgreen:
Re: travco parts
Unread postby Acesneights on Tue May 12, 2015 7:28 pm
I doubt you'll find any OEM stuff other than maybe once in awhile on eBay.
Re: travco parts
Unread postby 3rdranger on Tue May 12, 2015 8:02 pm
We'll get some pics up as soon as it's out of the shop. Waiting for the new rear tires.
3rdranger
Re: travco parts
Unread postby badbillybiker on Wed May 13, 2015 4:55 am
there are pics w/dims for a Travco aluminum screen door... only other source for one is to find a Travco that came with a screen door and the owner is willing to sell the one they have....FWIW.
matching gauges? Probably easier to replace and acquire the missing ones with new stuff...
Again IMO getting replacement OEm's are most likely going to be found on a trashed Travco or e-bay...
Re: travco parts
Unread postby 77Travco on Wed May 13, 2015 8:35 am
We use one of those "magic mesh" screen doors on our 270. Inexpensive enough to keep a spare and works very well.
Re: travco parts
Unread postby RobC on Wed May 13, 2015 1:27 pm
I rebuilt my entire instrument cluster with aftermarket (better) gauges that fit beneath the stock bezel instrument panel mount.
If you find the gauges you will need to replace the voltage regulator with a solid state chip and heat sink type to replace the crappy mechanical armature. Search Mopar instrument gauge voltage regulator. there is a really good tutorial for these dodge panels.
Rob
RobC
Travco Model: 1976 270
Re: travco parts
Unread postby Acesneights on Thu May 14, 2015 5:29 pm
Yeah I put an autometer voltmeter in the dash. The stock gauge on mine is an Amp gauge and they never worked very well.
Return to Travco 320/350
