Board index » Travco Motor Homes » Travco 320/350
our 320
Unread postby 3rdranger on Thu May 21, 2015 2:14 am
Trying to upload a photo of our 320.......let me know if it worked....
3rdranger
Travco Model: 1977 m320
Re: our 320
Unread postby RobC on Thu May 21, 2015 5:15 pm
Worked. Nice rig.
Re: our 320
Unread postby 3rdranger on Thu May 21, 2015 8:39 pm
Thank you. Rear diff is getting all new bearings a seals. King pins up front. Driveline rebuild, oil and coolant leaks ......then we go inside!
3rdranger
Re: our 320
Unread postby Acesneights on Tue May 26, 2015 7:38 pm
Wow. Nice rig. Garage kept too.
Re: our 320
Unread postby 77Travco on Thu May 28, 2015 2:45 pm
Sweet!... love the round headlight look.
Re: our 320
Unread postby 3rdranger on Thu May 28, 2015 4:47 pm
Love the paint! We're going to paint ours some day. Do you know where we can get new rubber for all the glass?
3rdranger
Re: our 320
Unread postby Acesneights on Thu May 28, 2015 6:37 pm
Foretravel still sells the windshield gaskets. Trimlok sells gasket by the roll for the side windows but it does no radius as well as the original since the originals were preformed I believe>
Re: our 320
Unread postby 7d6 Travco on Sat May 30, 2015 1:44 pm
That is sweet...I have a 320 as well and never see another traveling around.
7d6 Travco
Travco Model: 320
Re: our 320
Unread postby 3rdranger on Mon Jun 01, 2015 11:08 pm
Yours is a 76? Did it have disc brakes up front? Ours does but I'm not sure it's original. We have 5 hole wheels on one end and 6 hole on the other. Not sure if the front was swapped out or the rear.....
3rdranger
Re: our 320
Unread postby 7d6 Travco on Tue Jun 02, 2015 12:00 pm
Yes, '76. Disc brakes and hydraboost system are stock, as are the 5-lug on 8" spread wheels.
7d6 Travco
Travco Model: 320
Return to Travco 320/350
