our 320
- Travco Model: 1976 270
Re: our 320
Worked. Nice rig.
- Travco Model: 1977 m320
Re: our 320
Thank you. Rear diff is getting all new bearings a seals. King pins up front. Driveline rebuild, oil and coolant leaks ......then we go inside!
Re: our 320
Sweet!... love the round headlight look.
Re: our 320
Love the paint! We're going to paint ours some day. Do you know where we can get new rubber for all the glass?
Re: our 320
Foretravel still sells the windshield gaskets. Trimlok sells gasket by the roll for the side windows but it does no radius as well as the original since the originals were preformed I believe>
- Travco Model: 320
Re: our 320
That is sweet...I have a 320 as well and never see another traveling around.
Re: our 320
Yours is a 76? Did it have disc brakes up front? Ours does but I'm not sure it's original. We have 5 hole wheels on one end and 6 hole on the other. Not sure if the front was swapped out or the rear.....
- Travco Model: 320
Re: our 320
Yes, '76. Disc brakes and hydraboost system are stock, as are the 5-lug on 8" spread wheels.
