change Exhaust Manifold for new exhaust.
Unread postby Fraynez on Tue Aug 29, 2017 9:36 pm
Hello everyone. I would like to know if i can remove the old Exhaust Manifold. The ones that are cast iron and put in Center dump exhaust Manifold that are stainless steal. The passenger side has dampers. Do you need that? The new ones do not?
https://i.ebayimg.com/images/a/(KGrHqIO ... s-l500.jpg
The new ones.
https://i.ebayimg.com/images/g/pHcAAOSw ... s-l500.jpg
Will these work?
thank you for the help
Fraynez
Travco Model: 220
Re: change Exhaust Manifold for new exhaust.
Unread postby KB2CRK on Wed Aug 30, 2017 6:08 am
Those should work but it may need a little modification to the exhaust pipes to tie in properly. The damper is for heating up the manifold to supply warm air to the engine on cold starts. Just make sure you have the right ones for your engine. The 318, 413 and 440 all use different manifolds.
Unread postby Fraynez on Sun Sep 10, 2017 6:10 pm
Thank you for the info. I will let you know how it turns out.
Fraynez
Travco Model: 220
Return to Engines
