change Exhaust Manifold for new exhaust.
Travco Model: 220
Unread post by Fraynez » Tue Aug 29, 2017 9:36 pm
Hello everyone. I would like to know if i can remove the old Exhaust Manifold. The ones that are cast iron and put in Center dump exhaust Manifold that are stainless steal. The passenger side has dampers. Do you need that? The new ones do not?\n\nhttps://i.ebayimg.com/images/a/(KGrHqIOKkQE1p5zCm(WBNcnyrQK1Q~~/s-l500.jpg \n\nThe new ones.\n\nhttps://i.ebayimg.com/images/g/pHcAAOSw7htZlyEl/s-l500.jpg\n\nWill these work? \nthank you for the help
Re: change Exhaust Manifold for new exhaust.
Unread post by KB2CRK » Wed Aug 30, 2017 6:08 am
Those should work but it may need a little modification to the exhaust pipes to tie in properly. The damper is for heating up the manifold to supply warm air to the engine on cold starts. Just make sure you have the right ones for your engine. The 318, 413 and 440 all use different manifolds.
Travco Model: 220
Unread post by Fraynez » Sun Sep 10, 2017 6:10 pm
Thank you for the info. I will let you know how it turns out.
Return to “Engines”
