Re: What temp is everyone at
Unread postby Acesneights on Thu Apr 28, 2016 4:07 pm
Are you guys using actual temps measured by a thermometer or laser ? I would not trust the factory gauges.
Unread postby badbillybiker on Thu Apr 28, 2016 5:41 pm
Where would one use the laser/lazer for a true/accurate engine temp?
I have a couple of no contact temp units I use
on trailer tires, rv tires and exhaust pipes on the motorcycles...
Havent tried on the Travco yet.
Unread postby 77Travco on Fri Apr 29, 2016 10:48 pm
Acesneights wrote:Are you guys using actual temps measured by a thermometer or laser ? I would not trust the factory gauges.
I have a VDO manual temperature gauge installed on my dash. Before I installed it I checked it against a thermometer in a pot of water on my stove.
Unread postby highwaystar on Mon May 09, 2016 5:10 pm
My temp is based on a set of autometers I put in.
highwaystar
Previous
Return to Engines
