Travco's Do OR Die
Travco's Do OR Die
Unread post by datsit » Tue Apr 28, 2015 9:36 pm
UNHAPPY CAMPER !!! Will need to do some major surgery on BD over the next week or so. I did a inspection for this seasons trips, found some major problems, all the motor mounts are broken and engine has moved forward about an inch & leaning to the right, close but no contact of rad (thank god !!). Finding the mounts (in Canada) was difficult, Napa (#6021115) could find only one @ $21. no trans mount (listed as rear motor mount) Mopar #3632984 could be found !!!! My new best friend (parts guy !!) was able to locate last two front motor mounts in Canada at $14.each but no trans mount by any parts distributor (Dodge discontinued long ago) he slaved on for a few days and found THE rear motor mount !! 3 in North America, cost $90. (no shipping outside USA . Good to have US friends , 2 left on Ebay at $ 115 + ship. (different seller) This could have been the killer of BD or a load of $$$$ to make up this mount. There is not enough room to jack up engine to replace the mounts as we found out (damaging fan blades) needing to remove rad, p/s & alt, some rear brackets as well as headers to give us the height to replace mounts & move engine back to proper placement. It's going to take some effort BUT it's do or die so we'll DO !!!! Lesson here is to get under & check those mounts & buy them NOW or you may be parked for good !!!!!!!!!!!!
Re: Travco's Do OR Die
Unread post by RobC » Wed Apr 29, 2015 11:28 am
ouch.\n\nI feel your pain. I dropped some coin on my rig right after I bought it.\n\nNow's your chance for the Cummins swap......
Unread post by datsit » Wed Apr 29, 2015 12:38 pm
With the $$$$ spent on trans,motor,exhaust complete with headers & carb upgrades, we'll DO !!
Unread post by 77Travco » Wed Apr 29, 2015 4:25 pm
Well that's not encouraging... :o After reading this, I'm scared to look at mine.
Unread post by KB2CRK » Thu Apr 30, 2015 10:51 am
Just ordered a trans mount off of ebay. Just another question, Which motor do you have Datsit? Are the mounts the same for the 440? I found that part number on Napaonline but I want to make sure it is right before I order a few.
Unread post by datsit » Thu Apr 30, 2015 11:58 am
I have the 318ci with 727 trans. You should have the 727 trans This is the mount needed.
Unread post by KB2CRK » Thu Apr 30, 2015 12:00 pm
That is the trans mount I ordered. I was wondering about the motor mounts.
Unread post by datsit » Thu Apr 30, 2015 12:44 pm
This is the part # 6021115 for 318 360 383 413 & Belvedere, unknown for 440.
Unread post by KB2CRK » Thu Apr 30, 2015 1:08 pm
If that number works for the 440 Napa still has them listed. The 76 model year may be different but I am hoping it is not. Thanks for the info.
Unread post by Acesneights » Thu Apr 30, 2015 6:56 pm
When trying to look things up on NAPA's website you may have to try different years or models. Also don't forget, Travco used chassis they had laying around so a 1975 Travco might have a 1974 Chassis.\nBasically any 440 M series mount would work I would think so if you have a 1973 270 with a 440 a mount from a 1975 220 440 is probably the same. Also have you looked into aftermarket parts ? I would think energy suspension might make a Trans mount for a Torqueflight. Fairly common maybe ?? Just some ideas. My mounts don't look all that great either.
Return to “Engines”
