Part#s Sticky
Re: Part#s Sticky
Unread post by KB2CRK » Wed Sep 28, 2016 8:29 am
Brake Rotor for the M500\nCentric Parts 120.67010\nThe dimensions are the same as the KIC 666-13380 that has been listed here previously and it is available through Amazon.\nI saved a few bucks by ordering from Amazon themselves as I was just stocking spares. It took them a month to get the first one and the second one is due here Monday. Others sellers also have them for about 20 bucks more but they are in stock.\n\nhttps://www.amazon.com/gp/product/B001BFTVBW/re ... UTF8&psc=1
Re: Part#s Sticky
Unread post by kingdome627 » Fri Jun 23, 2017 1:02 pm
I know this thread is old, but I never saw a post that Definitively says that the Centric 130.83006 master cylinder will work on Late M375 chassis. MY 1972 Dodge Travco. \n The casting on the new master is 30042-C. The only difference I see is that the Front port will need a 1/2" to 7/16" adapter. (I saw a thread where someone paid $400+ dollars from Alretta that had this exact casting with the adapter) I paid $180. I am installing it this weekend and i'll report back if it works. \n Sean
Re: Part#s Sticky
Unread post by kingdome627 » Fri Jun 30, 2017 1:12 pm
The Brakes seem to be working fine after replacing the new master cylinder rod with the old one. So the Centric part # is correct for the M375 late chassis.
Travco Model: '71 270
Re: Part#s Sticky
Unread post by rjsdotorg » Wed Jul 15, 2020 4:22 pm
Got an email reply from Shaun Shroff at DuraBrake Co. 408-748-0400 x109
regarding drums for ~1971 M375 front (Budd 93906 brake drum):
"It looks like our part number 13906, I would guess its right, since our number is very similar to the Budd one, 13906 and 93906. I have attached a drawing.
I have 8 of these in Northern California. $398 each plus UPS freight plus sales tax"
13906RevA.pdf
Travco Model: '68 270?
Re: Part#s Sticky
Unread post by Mountainmade » Sat Jul 18, 2020 1:50 pm
Dibs on two of those
Return to “Brakes”
