size of bleeder bolts on '71 270 Mahal?
Zed
Travco Model: 270 Mahal
Unread post by Zed » Sat Aug 20, 2016 3:41 pm
I want to order Russel speed bleeders as a first step towards sorting out my Travco's brake problems. Bleeding the system may be all it needs as I haven't found any obvious wheel cylinder failures and the brakes mostly feel mushy and don't engage until the pedal is almost to the floor. \n\nAnyways does anyone know off hand whether the travco takes the 5/16ths or the 3/8ths sized bleeder valves? Thanks.
Re: size of bleeder bolts on '71 270 Mahal?
Unread post by Acesneights » Mon Aug 22, 2016 8:31 pm
I don't remember but I would pull a wheel(I know it sucks on full floaters) and look at the wheel cyls. If it has been sitting, they are probably bad.
Travco Model: 1966 Model 270
Unread post by Fellchase » Sun Aug 28, 2016 7:53 am
We have 66 model P375 put the Speed Bleeders on it the fronts and backs are different size good luck.
Return to “Brakes”
