size of bleeder bolts on '71 270 Mahal?
Unread postby Zed on Sat Aug 20, 2016 3:41 pm
I want to order Russel speed bleeders as a first step towards sorting out my Travco's brake problems. Bleeding the system may be all it needs as I haven't found any obvious wheel cylinder failures and the brakes mostly feel mushy and don't engage until the pedal is almost to the floor.
Anyways does anyone know off hand whether the travco takes the 5/16ths or the 3/8ths sized bleeder valves? Thanks.
Zed
Travco Model: 270 Mahal
Re: size of bleeder bolts on '71 270 Mahal?
Unread postby Acesneights on Mon Aug 22, 2016 8:31 pm
I don't remember but I would pull a wheel(I know it sucks on full floaters) and look at the wheel cyls. If it has been sitting, they are probably bad.
Unread postby Fellchase on Sun Aug 28, 2016 7:53 am
We have 66 model P375 put the Speed Bleeders on it the fronts and backs are different size good luck.
Fellchase
Travco Model: 1966 Model 270
Return to Brakes
