No brakes at all in '68 270
Unread postby mabrandes on Fri Aug 26, 2016 5:43 pm
Now that I have the motor running... time to focus on the brakes... of which I have none. The MC was replaced in 1980. It was empty of fluid.. so I added some in. Pedal just goes to floor, no resistance at all. I'm reading service manual but would love to here any thoughts. Do I need pull MC and bench bleed it?
I also found a spring hanging loose from the pedal mechanism that I can't see an obvious place to attach the other end.
Matthew,
Wellsville, KS
1968 Dodge Travco 270 | 2010 Teardrop | 1966 & 1968 Utopia Pan-O-Ramic TT's | 1950 Spartan Royal Mansion | 1969 Arisocrat LoLiner |1964 Barth TT
mabrandes
Travco Model: 1968 Travco 270
Re: No brakes at all in '68 270
Unread postby Acesneights on Fri Aug 26, 2016 8:07 pm
How long did the Travco sit ?
Unread postby mabrandes on Fri Aug 26, 2016 9:21 pm
Acesneights wrote:How long did the Travco sit ?
Not sure last time it was driven. At least 2 years as tat is how long it was sitting at corner for sale. I'm going to bleed the brake system aND see how far I get.
Is there anyway to test hydro vacuum brake boosters first? I assume if they need rebuilt that would require the system to be bled again.
Matthew,
Wellsville, KS
mabrandes
Unread postby 77Travco on Mon Aug 29, 2016 7:17 am
Try bleeding first. Wheel cylinders will almost certainly need to be replaced but you wont know until bleeding and testing each wheel for braking ability and leakage.
Unread postby mabrandes on Mon Aug 29, 2016 8:11 am
77Travco wrote:Try bleeding first. Wheel cylinders will almost certainly need to be replaced but you wont know until bleeding and testing each wheel for braking ability and leakage.
Someone else mentioned wheel cylinders, so I may just proactively replace them.
Matthew,
Wellsville, KS
mabrandes
Unread postby Acesneights on Wed Aug 31, 2016 4:00 pm
Correct. You could pull the vac lines off and see if there is any brake fluid in them.
Return to Brakes
