Re: 1975 270 Disc Brake pressure not releasing
Unread postby diskman on Sat Nov 05, 2016 7:22 pm
Yep. I checked that first thing. There is no "preload" on the spring at all. It's bottomed out completely at pedal TOP. Maybe tomorrow I will look at adjusting the spring a bit. Looks like lubricating everything helped a bunch.
Pretty severe power steering leak now too. Dripping into my neck as I was working on the brake situation. ugh.
Scouring my wiring schematic so I can go probe around and see where my failure point is on the brake lights not working.
It's always something. :) Gotta love 40 year old vehicles that sit.
diskman
Unread postby KB2CRK on Sat Nov 05, 2016 7:43 pm
Check the switch. It is also in that picture top center. That is not an original switch but a $7.00 Standard brand With a couple washers to allow mounting in the factory spot.
Unread postby diskman on Sat Nov 05, 2016 7:51 pm
Found the problem. Traced the wires back to the RED/Yellow plugs by the footwell. Pink wire SHOULD be hot, White wire is from brake switch.
Pink wire was dead. Traced back to fuse panel and found a bad fuse. NOT blown, just flat out old and bad. Continuity test shows 0, Zero, Zilch through fuse.
Replaced with fresh 20A from collection and pink wire is now 12V. White wire from switch gets juice when brake is applied. Waiting for wife to confirm lights working but all signs say yes.
The spring still needs to be adjusted to pull the pedal up that last 1 inch or so. Will lay under there tomorrow and see what I can adjust.
Thanks all!
diskman
Unread postby Acesneights on Sun Nov 06, 2016 8:50 pm
Stub Shaft seal ?
Previous
Return to Brakes
