Steering Gear Box
Unread postby badbillybiker on Thu Sep 17, 2015 6:13 pm
Is there a replacement for the steerung gear box on a 1974 Travco..
Think mine is shot? Other components are in great shape...
Need a part number and a source... or.....
A company name & location that rebuilds this item...
TNX for any help with this... believe its all adjusted in
Re: Steering Gear Box
Unread postby Acesneights on Thu Sep 17, 2015 6:29 pm
Why do you say it's shot ? Most of these have low mileage on them and generally just need a seal kit.
Unread postby badbillybiker on Thu Sep 17, 2015 8:02 pm
Just need to get rid of one more headache...finally got mine back today. Was driven to my storage area and driven along a twisty and winding road... Steering was going from point to point in a wide arc. On a interstate the wander was very minimal... has over 80k.. presume the sector gear and adjusting screw is worn. Would just as soon rebuild or replace.. and get rid of one more problem.
BTW...it is not leaking, indicating a seal problem..
Unread postby Dave78Chieftain on Fri Sep 18, 2015 6:28 pm
First make sure the steering wheel shaft to steering box coupler is not wore out. If it is, post back, as I know how to solve it.
Dodge P/N 3497240 (Saginaw Model 708)
Power Steering Specialist (PSS)
PSS PDF Catalog
Dodge 3497240 cross-ref to PSS P/N 44-2011 (pdf page 77) You will need to call them as while they cross-ref the Dodge P/N they do not show it in their catalog
Redhead Steering Gears Would have to contact them
Dave78Chieftain
Unread postby badbillybiker on Fri Sep 18, 2015 8:48 pm
TNX Dave....Westerville is drivable from Cleve to pick one up....
