Power steering cylinders on a '67 270
Unread postby NobleTruths on Mon Sep 28, 2015 9:03 pm
1967 Travco 270 P375 w/ 318 motor.
I have removed the power steering hydraulic lines due to their poor condition and leaking. Having them rebuilt locally. While they are off, I figure I should address other related issues. The large hydraulic cylinder that connects to both wheels is also leaking where the piston enters the housing (see attached picture). I don't know the name of the cylinder or p/n, but does anyone know if it is rebuildable? If yes, any purchase source would be wonderful. Also, the bushings on their end could use replacement. Any p/n on those?
The smaller cylinder that the 4 lines attach to (see picture) is not leaking, but I could rebuild that while I am at it, if anyone has a p/n for that....and its bushings, too. I have no idea if I should rebuild the PS pump or any other components. Thoughts?
I read that ATF is used for the PS fluid. Is that correct? DexIII, or something else? And what ATF is used in my transmission?
Thanks.
NobleTruths
Travco Model: 1967 Travco 270
Re: Power steering cylinders on a '67 270
Unread postby Dave78Chieftain on Tue Sep 29, 2015 5:21 pm
Dave78Chieftain
Unread postby NobleTruths on Tue Sep 29, 2015 9:13 pm
That is perfect!! Thanks so much!!
And is the PS fluid just ATF? Which type?
NobleTruths
Unread postby Dave78Chieftain on Tue Sep 29, 2015 9:58 pm
Dodge P/N 2084329 is recommended but no longer available.
From what I read, ATF is not recommended for this paticular application (attacks seals and hoses)
Far as I know you can use Prestone Power Steering Fluid & Stop Leak
Dave78Chieftain
Unread postby NobleTruths on Wed Sep 30, 2015 9:43 am
Thanks!
NobleTruths
Unread postby 77Travco on Wed Sep 30, 2015 8:14 pm
Wow Dave... thanks for posting!
