Perplexing rear clearance light issues
Posted: Wed Jun 19, 2019 12:27 am
Very close to getting safety inspection completed on my 73 220. All lights were working .... then something changed and rear clearance rights no longer work. All other exterior lights including front clearance work fine. Some visual tracing has been done - under stop lights etc.
I saw this in response to another post about Chassis DC Fuse Panel Issues.
EDIT: An LED license plate lamp was connected shortly before the rears stopped working. We then unhooked it and no change. I did see a schematic, I think, that indicated the license plate light is connected to the stop lamp wiring. So that is probably worth investigating furher.
Though cryptic I think I saw some of what you were saying under the stop lights. I don't understand the split front to rear tho. I am looking more closely at the schematic posted in the thread. Any thoughts ?The clearance lights are powered through the headlight switch as part of the parking light circuit. I know that sounds a bit ambiguous but it's a start.The fuse would be under the dash area... Do your dash, front park and tail lights work?
