Onan 6.0K NH genset
Re: Onan 6.0K NH genset
Unread post by KB2CRK » Thu May 14, 2015 1:30 pm
Doing a little reading in the manual and the 6.0 NH is rated for 50 amps. That explains the 50 amp plug in the storage area. This also means it will run both roof ac units after the second one is in.
Unread post by Acesneights » Sat May 16, 2015 4:25 pm
My 270 has the 50 amp plug too. My old 1970 220 has a transfer switch in the closet.\nWhen working on these old gensets, A hertz meter is a golden tool. I have mine dialed right in at 60 cycles at mild load.
Unread post by KB2CRK » Sun Jun 14, 2015 10:34 am
Any one know what the torque spec is for the flywheel/fan bolt? Had to pull the flywheel to pull the broken starter bracket. The bracket is welded up and ready to go on. The end of the crankshaft is tapered and the flywheel/fan is cast. I want to make sure It is right the first time. I found the broken bracket when the starter quit (it was being cantankerous) and pulled a rigged up brace off the back.
Unread post by badbillybiker » Sun Jun 14, 2015 3:06 pm
here is a Onan CCK 6KW PDF manual.... HTH\nThere might be applicable torques that you can use...\nAlso for the 6 KW NH's.\nBBB
Unread post by KB2CRK » Sun Jun 14, 2015 6:19 pm
Well it is not in the user/parts manuals. Thanks for the Gm manual as it has more than the one from Onan.\nI found the specs here. http://enginemastersinc.com/onanrebuild ... mation.htm
Unread post by Dave78Chieftain » Sun Jun 14, 2015 6:32 pm
Spec A-H manual says 30-40 ft lbs. \nhttp://www.twinslan.net/~n0nas/manuals/ ... -1973).pdf\nSpec J-R manual says 35-40 ft lbs .\nhttp://www.twinslan.net/~n0nas/manuals/ ... -1983).pdf
Unread post by KB2CRK » Sun Jun 14, 2015 7:01 pm
Thank you very much Dave. The page I found said 50 ft lbs but it did not feel that tight coming apart.
Unread post by Dave78Chieftain » Sun Jun 14, 2015 7:28 pm
As long as you know the spec number of the NH generator you have, almost anything you will need to know is in the associated manual I pointed to.\n\nExample label plate decode\nImage
Return to “Electrical”
