Proper oil in Onan 6.0 CCKB
Unread post by highwaystar » Sat Jun 27, 2015 9:54 am
Changing the gen oil, previous owner has been running non detergent 30. It is printed on the Onan that it wants detergent oil and the internet confirms this. \n\nWould like to run the 10w 30 amsoil zrod I run in the other old cars but concerned about switching to detergent after 750 hours. Does anyone have any thoughts? It runs great and it doesn't look like a fun project to pull it.\n\nAlso, appears that this unit does not have an oil filter, does that sound correct.\n\nThank you,\n\nKarl
Re: Proper oil in Onan 6.0 CCKB
Unread post by 77Travco » Mon Jun 29, 2015 8:04 am
I wouldn't worry about changing it to detergent oil. \nMine doesn't have an oil filter either. I just run 30w automotive oil in it.
Unread post by badbillybiker » Wed Oct 21, 2015 3:18 pm
At 1045 hours put on by PO's... I drained absolutely filthy oil out of the Onan 6kw CCk.\nThis is the same as what was in the 76 i had. No oil filter. Replaced with three (3) quarts\nof plain 30 weight oil to the full dipstick mark. Ran for a bit and the oil looks clear as olive oil for now...\nNow... Where do I get and what are the part numbers for the points, rotor etc. for these\nbrutes..also can't seem to find a PDF nanual for the 6000 CCK Onan... \nBBB
Unread post by Dave78Chieftain » Wed Oct 21, 2015 7:29 pm
CCKB Operators Manual\n\nCCKB Service Manual\n\nCCKB Parts manual (Refer to Mobile home section pdf page 34)\n\nCCKB Ignition Parts
Unread post by badbillybiker » Thu Oct 22, 2015 2:17 am
Dave.. Thank You... All I could come up with/find, was up to a 5kw unit...\nI am sure others have had the same frustrating 6kw problem...\nand can now add these files to their library.\nDarn thing fires right up and is still running great but with a slight \nflickering that is tolerable for now...\nHave switched to almost all SMD lighting for less voltage consumption...\nBBB
Unread post by Ryemaddamazin » Thu Jul 25, 2019 12:23 am
Bbk can i get some pics of yojr gen set i got same onan 6.0 but I think its missing fuel pump. Is ur pump located on front of gen set?
Return to “Electrical”
