1971 dodge travco 270
Place your for sale ads here. it is ok to place ads you find for Travcos for sale that you do not own also.
Unread post by brockway27 » Wed Jan 13, 2021 1:19 pm
this is a 1971 dodge travco 26' motorhome. it has a 413 chrysler engine that runs very well with good oil pressure. we have been driving it around the yard so the trans. sounds good but we have not taken it out on the road. someone drilled holes in the roof to add things on at some time. some of those holes leaked water down in. so it needs a total redo of the interior. we have started stripping it out. the good news is that the travco used very little wood in its frame. the paneling and ceiling all attach to steel so redoing is much easier then others. all of the original equipment is in it. it has an onan generator that turns over and has spark. i have not tried to put gas in it. the camper only has 29000 original miles on it. the tires have good tread but they have some age. the bad news is that the brakes do not work. i pulled the drums and they look good and the shoes look good as well. there is a truck garage near us that is willing to take a look at it and fix the problems. i have no idea what the cost will be but if interested i can give their number and you can call them and talk it over. the body is in over all good shape. it would need painting. all the glass is in it and there are no cracks or breaks. there is some smoking in the windshield but not enough to cause an inspection problem. asking $3500. if you have any questions please feel free to give me a call. 8 one 4 three 8 six 9 five 3 seven thanks
Return to “Travcos for Sale”
