Board index » Classifieds » Travcos for Sale
Place your for sale ads here. it is ok to place ads you find for Travcos for sale that you do not own also.
1973 Travco 270 for sale
Unread postby Bellytank on Thu Feb 09, 2017 4:32 pm
I have a 1973 travco 270 for sale. It is currently not running due to a rusty stuck shifter cable I think. The tranny is stuck in a forward gear so the neutral switch isn't operating. When the weather breaks her in North Idaho I'll go and lube it up and see if that cures the problem.
This model has the bathroom in the rear and its nice sized. The plumbing has been replaced with pex pipe tubing through out so if you for get to winterize you shouldn't break any pipes. The fresh water pump has few hours on it replacing the original a few years ago.
Mechanically it needs work on brakes. Lights could use a tinker to. Sadly the iconic spotlight was stolen some years ago. The motor is a low mile 440-3 replacing the old 413. For some reason the steering column was replaced by the previous owner with a piece of crap from a minivan but I have the correct column ready to install.
All the appliances work and the old suburban heater has been replaced with a efficient Olympic catalytic heater. the floors are covered with wood tone laminate and look nice. There is fresh paint through out. There is a leak in the forward ceiling but I think re-caulking the clearance lights will fix that. The front air conditioner was damaged and temporarily replaced with a standard vent. Rear ac works well but could use a service. The generator won't start and will need some work. Its not the original but I did see it operate at one time. There is more so please email me your questions. This RV is represented as a project and some work will need to be done to it. Thanks for your interest. Shaun
Bellytank
Re: 1973 Travco 270 for sale
Unread postby Acesneights on Thu Feb 09, 2017 8:48 pm
Feel free to post some pics and a price. Hopefully someone will give her a new home.
Unread postby Deb on Tue Aug 15, 2017 11:48 pm
Pictures etc?
Deb
Travco Model: Looking
Return to Travcos for Sale
