1969 travco 270 for sale in cincinnati
- Travco Model: 330?
I checked out this neat dodge travco for myself, but have too many other projects going on right now. http://cincinnati.craigslist.org/cto/4103107580.html\nThe owner has completely redone all the brakes, including new brake lines, but needs to fill the master cyl with fluid because the pedal goes to the floor. He also has the fuel pump removed because there is 'stuff' in the gas tank, but he starts and runs it with a gas can directly into the carburetor. The exterior has deep crazing of the gelcoat all over, and on the passenger side there are a couple area where it is extensive. The generator is there but needs carburetor work. the gen shows 568 hours on it and the odometer shows 27,ooo, probably 127k. He lit the propane stove for me and it works great. the 2 roof ac units both run but I don't know if they cool. the fans operate and the compressors also come on. I hope someone has the time and money to restore this neat vehicle!
Re: 1969 travco 270 for sale in cincinnati
$1100 ain't bad... I wonder what that white, upside down bowl looking thing above the drivers area is ?
tv antenna He said
