Board index » Classifieds » Travcos for Sale
Place your for sale ads here. it is ok to place ads you find for Travcos for sale that you do not own also.
1970 22Ft 318, lots of new but needs work
Unread postby bryanspoon on Sun Mar 20, 2016 4:15 pm
I have a 1970 22ft Dodge Travco with the 318, simple carb, runs great, has lots of new but is using a lot of oil. Diagnosis says it will need a new head gasket most likely.
Things done:
New rubber all around + spare.
New shocks
New brakes all around
New Right header done
New blackwater tank
Hot water and AC works
Stove works
Fridge 'probably works' (according to my mechanic but I couldn't get it to work).
Has 2 tanks, 50 gallons in the back and 20 gallons - nice to fill up, turn the switch and go.
She had a leak inside once before I got her but I fixed it and she's dry and without mold - actually pretty clean.
I have spent over $10,000 on her, and just want someone to use her and fix her and run her - she ran last year all the way to Yellowstone in her and she was great, but then I had the header leak fixed ($1500) and then the oil leak.
Right window has a big crack, but everything pretty much works.
Don't low ball me too bad folks, I have receipts for over $10k of work, you fix the engine and you won't need brakes or rubber or shocks or or or ;)
Plenty of pics to send if I can't do it here ;)
bryanspoon
Re: 1970 22Ft 318, lots of new but needs work
Unread postby Acesneights on Wed Mar 23, 2016 7:47 pm
Location and asking price ?
Unread postby bryanspoon on Wed Mar 23, 2016 7:52 pm
Sorry, forgot to put that in. I am near Wenatchee, wa. Asking price is $3500.
bryanspoon
Unread postby Acesneights on Sat Apr 09, 2016 7:31 am
Dang, why does everything have to be on the other side of the country.
I'd be all over that. I assume it looks like the one in my Avatar ?
Post up some pics.
That sounds like the perfect candidate for a Cummins swap.
Unread postby Acesneights on Sat Apr 09, 2016 7:32 am
Wanna see the other side and inside... :mrgreen:
Unread postby Acesneights on Sat Apr 09, 2016 7:35 am
Using oil is not a sign of a bad headgasket unless the oil is in the antifreeze. Is the engine oil clean otherwise ? Is there pressure in the cooling system when yo first start it up ?
Does it smoke when running and if so what color and does it smell sweet or like burning oil ?
Unread postby TheFurys on Sun Apr 10, 2016 6:19 pm
Hello, very interested.
Can you send me a way to contact you directly?
Cheers
TheFurys
Travco Model: Looking to buy
Unread postby Travco-will-Travel on Wed Aug 03, 2016 3:59 pm
Is this unit still for sale?
Thanks
Travco-will-Travel
Travco Model: Travco 220
Return to Travcos for Sale
Users browsing this forum: No registered users and 1 guest
