Board index » Main Discussion Areas » New Members Introductions
Welcome...
Stop here first and tell about yourselves...
Re: Hello from Georgia
Unread postby KB2CRK on Thu Nov 20, 2014 1:18 pm
Oh yeah, found the VIN in the first place I looked. It was right were you said it was. She is fully registered.
Unread postby badbillybiker on Thu Nov 20, 2014 1:37 pm
I looked in my library and found ONE floor plan for a rear dinette mahal... HTH..
There are most model wiring diagrams at this site.. Just have to snoop a bit...
The bathroom I had and the one illustrated for your mahal was a stand over the
toilet arrangement. As there is only so much room/floor space they did a lot of
jiggling. In my current model, a 74, I have a full stand in/up shower with out the flex
hose attatched to the top of the bathroom faucette..but lost cabinet storage space
and elongated seperate beds in the rear with a small center night stand... I have a
rear dinette now giving up the longer beds. Win some/lose some.
Unread postby KB2CRK on Thu Nov 20, 2014 1:46 pm
The floor plan currently in mine is the Mahal special VIP which is the third down on the right in the 270 list. All the cabinets are in place as is the fridge. I have a little work to get a queen bed in the back but that will be in the works. The flooring is solid through out but the black water tank is a priority....
Unread postby 77Travco on Thu Nov 20, 2014 6:00 pm
The fuel tank in my 77 270 is 70 gallons. I had it out recently and measured it. I then put the numbers into a fish tank gallons calculator and came up with 72 gallons.
My dash air doesn't blow cold so I just run the genset and roof air when driving in hot weather... it works pretty well for me.
My coach has the rear dinette setup also but I don't think its a Mahal. I have mine registered as an antique vehicle.
Unread postby badbillybiker on Thu Nov 20, 2014 6:17 pm
Can you see the or do you know the model of the genset?
I believe if it's a OCCK model there is already a PDF manual one posted for that unit...FWIW
FWIW & My $.02 worth of chit chat...:
A MAHAL model AFAIK has the door in the center of the Travco...
Certain Mahals also have a 2+2 emblem on the passenger side only, next to or below the Two-Seventy emblem.
In the 270 Mahals they came with a cone style easy chair ...
The 220's (Certain models) 290 & 320 I believe all have/had center located door.
The 210 & 270 have the FLXIBLE style rounded rear. The 220, 290 & 320 & up all are/were flat backed...
AFAIK
Subject to corrections.
Unread postby 77Travco on Fri Nov 21, 2014 7:29 pm
@BBB... Sounds right to me.
Unread postby badbillybiker on Sat Nov 22, 2014 10:00 am
Here is a ONAN CCK PDF File... While it's not the exact manual, it should get you going.
I really was looking for my OCCK B manual, but like a lot of things, I'm sure I put it where
I would remember... CRS...HTH
When I locate what I am sure is a closer manual, I will post it as a PDF or I will ZIP it...
Unread postby KB2CRK on Sat Nov 19, 2016 9:54 am
Here it is 2 years since I bought Nessie home and from the day I joined the Forum. What is interesting about today is that I am working on Nessie getting her ready for our next trip to St George Island FL. Behind the eight ball to start having to repair some wiring on the engine due to our Dachshund chasing out cat up into the engine compartment and having a war in there. Moved her onto the driveway and letting the headers cool so I can put the wiring back together without burning the hell out of my arms.
Previous
Return to New Members Introductions
