Board index » Exterior » Glass and Gaskets
Window gasket & weather seal
Unread postby datsit on Tue Mar 18, 2014 7:54 pm
I have the weather & glass seals for the HeHr crankout windows for the kitchen & bath, also for the floor vents, $ by the foot
datsit
Re: Window gasket & weather seal
Unread postby Acesneights on Thu Mar 20, 2014 4:44 pm
Where did you get them ?
Unread postby datsit on Thu Mar 20, 2014 7:07 pm
When I did my windows I had to buy a minimum 25-30 ft ?? so I have a few feet left.
datsit
Unread postby badbillybiker on Mon Mar 31, 2014 7:43 am
Question: Who is the source, cost, part number etc.
Would like to order same but there are so many
places to hunt for the correct/working item on the internet, ..
Are the few feet left for sale?
How does one go about purchasing items from members
on/thru this site.??
Unread postby datsit on Fri Apr 11, 2014 6:03 pm
BBB What year is your Travco?, The w/seal & glass gasket is for the HeHr crankout windows, kitchen & bath, window to frame, glass to frame body, and the vent door to frame on floor vents. The supplier (only one) has a minimum 24 or 48 foot order, so I have about 15 feet left (???) of each seal $2.00 a foot.
datsit
Unread postby badbillybiker on Sun Apr 13, 2014 3:57 am
1976:
I do not recognize that window...
Unread postby datsit on Sun Apr 13, 2014 1:39 pm
This window is on pre 1970 Travco's, all years Travco's use same w/seal for floor vent.
datsit
Unread postby Acesneights on Sun Apr 13, 2014 6:15 pm
Yeah, I would probably just replace those with later model windows. They are easy to find from an RV salvage. Those screw in vs Gasketed. Problem with them is the crank mechanism on the factory Travco ones are obsolete with no know parts(that I know of) and the cranks do break. In fact I eventually wanna can all the windows in my Travco for updated ones. The slinding windows leak no matter what you do. They were a poor design.
Return to Glass and Gaskets
