Board index » Exterior » Body, Paint Gelcoat specific
Skirts, what years/models had them?
Unread postby rcb on Mon Mar 25, 2013 10:22 am
As mentioned elswhere, IF we end up with a Travco (one of the contenders), I'd like to find one with the lower skirts. Assuming they are like some other skirted vehicles I've dealt with, I know tire changes take... technique.
That said, it seems like I've seen the same year with skirted and unskirted bodies. Anyone able to illuminate me? :)
rcb
Travco Model: Looking for 210
Re: Skirts, what years/models had them?
Unread postby 77Travco on Mon Mar 25, 2013 11:27 am
I think you may be talking about different year models. The 68 and older body style may be what you are refering to as "skirted".
The 69 and newer look "unskirted" and the grills and headlight placement changed again in 72 (i think).
Unread postby rcb on Mon Mar 25, 2013 11:58 am
Ok, I must have been looking at mislabled pictures.
Now I've seen a "skirted" pre 68 with single headlights. Were the twin headlights on all or only some models? I was under the impression that all Pre 68' were twin headlight style.
Like this one
http://www.carsgozoom.com/buttercup/about/
rcb
Unread postby 77Travco on Mon Mar 25, 2013 12:54 pm
The 1968 and older Travco 270's had 4 headlights.
In 1969 the 270's went to only 2 headlights that were still mounted up high. (Like the 220's)
In 1972 or 73 the 270's 2 headlights were moved down.
220's always had just 2 headlights.
I believe the above is a true statement... :)
Unread postby rcb on Mon Mar 25, 2013 2:32 pm
Regarding 210's... are there any with twin headlights? I've seen several with the skirting, but none with the twin headlights/
rcb
Unread postby 77Travco on Mon Mar 25, 2013 5:07 pm
I have to be honest with you... I just realized that a 210 and a 220 were two differen't coaches. I thought we were talking about the same thing... lol... As far as I know... the only Travcos that came with 4 headlights were the 68 and older 270's.
I am not sure about the 210's or 220's so maybe someone else will chime in here.
Unread postby Acesneights on Mon Mar 25, 2013 7:05 pm
the headlights were up high until 73 on all of them. In 74 down low. I always liked the Older ones better. I think pre 69 was skirted but I could be off a year.
Edit: I have now seen 2 73 270's with headlights down low but I personally owned a 73 with them up high so maybe a split year ???
Unread postby Operation68Travco on Sun Sep 08, 2013 10:47 am
I have a 68. No skirts there, but the four headlight configuration is in effect.
Operation68Travco
Travco Model: 68 Travco
Unread postby 77Travco on Mon Sep 09, 2013 2:08 pm
You gotta post up some pics when you get a chance!
Return to Body, Paint Gelcoat specific
Users browsing this forum: No registered users and 4 guests
