Finished painting my Travco
Unread postby 77Travco on Sat Mar 26, 2016 7:38 pm
OK... I know I'm gonna get some haters here for painting over those tasty 1970's waves but my old paint job was pretty faded and never was my favorite anyway. I now have a gray paint job with a silver roof and bottom. I am considering putting a large Travco bird symbol on the side or maybe some sort of bright colored stripe. All suggestions are welcome... I will update when I do more paint work.
Here are a few pics of my 270's current paint scheme.
Re: Finished painting my Travco
Unread postby Dodgy71 on Sat Mar 26, 2016 7:46 pm
Rustoleum again? Rolled not sprayed, right?
I kinda liked your waves, as opposed to the off white (or whatever color it is), with a colored stripe, that most Travco's came with.
Dodgy71
Travco Model: 1971 270
Unread postby KB2CRK on Sun Mar 27, 2016 8:05 am
It looks great. I am curious if you painted it the same way you did the roof. What kind of paint did you use? Nessie is in need of paint and if I can roll it on to make it look that good I would go the same route.
Unread postby 77Travco on Mon Mar 28, 2016 7:46 am
Rustoleum and roller method. Other than a few runs, it came out looking pretty good! I think my next step is to paint a 1" wide black stripe everywhere the silver and grey meet.
Unread postby KB2CRK on Mon Mar 28, 2016 7:52 am
Awesome. Rustoleum makes a royal blue in the industrial paint along with white. Did you do any sanding prior to paint or just a really good cleaning? Nessie with be royal blue below the stripe and white above and we are looking for a vinyl wrap for the stripe which will be the Stewart Royal Tartan.
Oh yeah, what size nap on the rollers and how many gallons did it take?
Sorry for all the questions but this was an option we were looking at but were unsure on how it would look.
Unread postby badbillybiker on Mon Mar 28, 2016 5:51 pm
There are loads of utube mini-movies on how to paint your rv etc.
I did a search quite a while back on the subject of how to etc. for mine.
Here is a starter site/point to get you going.. On the right side bar will
be many variations. Peruse/cruise thru them...
I have ripped those out that I felt would be of use to me.
BTW... I use a-tube catcher on XP... to build my utube library...
They are too big to send over the internet... So here is a URL starting point.
Preferred method after viewing a number of methods is a small FOAM diameter
roller of ... 4" length micro-size... and thinned Rustoleum...by 25% ? CRS!.
FWIW/HTH
https://www.youtube.com/watch?v=BTO3q7Bpkbw
Unread postby 77Travco on Tue Apr 05, 2016 11:11 am
KB2CRK wrote:Awesome. Rustoleum makes a royal blue in the industrial paint along with white. Did you do any sanding prior to paint or just a really good cleaning? Nessie with be royal blue below the stripe and white above and we are looking for a vinyl wrap for the stripe which will be the Stewart Royal Tartan.
Sorry, I've been away.
I washed and scrubbed the entire coach. I used those green scrubbing pads that they sell in the paint section at Lowes or Home Depot. Right before painting, I wiped it down with paint thinner for a final cleaning.
An entire Travco 270 will use right at 1 gallon if you put on 2 coats (I'm including the roof). I mixed about 25% thinner into the paint but that is probably too much. I would start with around a 90/10 paint/thinner mix next time.
One thing that I figured out was to use high quality paint applicators. I used a roller labeled for super smooth surfaces and a very soft brush.
Unread postby KB2CRK on Tue Apr 05, 2016 1:27 pm
No problem with the delayed reply. We are In Edisto Beach SC Camping in the Travco until tomorrow. This is the first time the laptop has been online since Saturday. The range extender works for the internet although a little cantankerous to set up at a new site. Thanks for the great info and the scotch brite pads do a great job at cleaning and a slight scuffing. It will probably be in the fall but Nessie will be getting a white and royal blue paint job now using the Rustoleum method. Maybee in a few years we will look for a professional job but for now the roller method will be the way for us to go.
Unread postby padave29 on Thu Apr 21, 2016 4:14 pm
Looks good! And it definitely inspired me to do my own! I may go all out, though, and use a boat paint. I figure it's a fiberglass hull - just like my sailboat - only not in the water. I'll put some "Before" pictures up here soon - she's a real eye sore right now.
padave29
Travco Model: 1973 - 270
Unread postby 77Travco on Tue Apr 26, 2016 10:24 am
Here's a few more pics. I added thin black stripes to divide the grey and silver. I may go wider with the striping but not sure yet.
