travco Owner's manual
Re: travco Owner's manual
Yup, it's the Travco manual. I have separate manuals for the stove and fridge too.
That is cool. I love the fact that Nessie is the middle picture.....I would love to get a copy of those manuals.\n\nI even have one of those hub caps.....
PM sent.\n\nI have one of the hub caps too. And one other hubcap. And a spare tire mounted on a rim that's the wrong size.
\nWe have a pretty high limit on file sizes. Did you try ? If you can't then email me and I will override it.The Dane wrote:I have one. Too big to post here though.
My limitation is that I don't have a scanner. I'll check around to see if I can get someone to do it for me.
have a set of 4 hanging on the garage wall...\nBBB
here is a "owners" manual I zipped into 4 sections... HTH...\nNot sure of the year or models...\nBBB
Thank Billy... I just saved the whole manual to my laptop. Should make for some interesting reading.
Do you still have owner's manuals left? If so, I'd love to have one. IF not, I'd at least like to know the tow rating for a 270 if you have that somewhere.\nThanks
there are all types of manuals on this TravcoForum site... Specifics will need to be searched... \nI don't know but am sure someone has that knowledge and will surely post it...\nI believe the GVW including the weight of your unit (with contents and passengers), gas, water and propane...\nand the gross weight of your tow will give you the recommended answer...\nAnother determining factor will be condition of the Travco's braking system and whether your "toad" brakes are operable from a brake controller to assist in stopping. HTH/FWIW/IMO\nBBB
