Broken in jasper AL
On the road ? Broke down ? Need help fast ?
\nPost here...Maybe someone is near by or we can atleast give you advice.
Broken in jasper AL
Unread post by Dodge Dreamsicle » Fri Jun 21, 2019 8:37 pm
Broken belt in Jasper AL
Does anyone have a diagram of the belt path (looks like it’s alternator to the air conditioner compressor and something else.... I think I have a spare but not sure it’s path. Can anyone talk me thru it?
Kevin
Keugewilliams@gmail.com
253.225.5654
Travco Model: 220
Re: Broken in jasper AL
Unread post by Woodsman » Sat Jun 22, 2019 4:18 am
My manual shows 2 belts, one to run either side of the engine. It doesn't show an air conditioner compressor just the alternator on the left and power steering on the right.
Unread post by KB2CRK » Sat Jun 22, 2019 7:04 am
one belt goes from crank to water pump to power steering pump.
Second belt is crank to water pump to alternator.
a third belt which I do not have on would go from the crank to ldler to AC compressor.
This is a picture of the front of the engine with a different style alternator so it is not all bolted up yet.
This is for the 440 in a 270/ Mahal. You did not mention which Travco or engine,
Unread post by KB2CRK » Mon Jun 24, 2019 11:36 am
Did you get it going??
Unread post by datsit » Tue Jul 23, 2019 10:25 am
Did you get FIXED ???
Return to “Travco Emergencies”
