ZF 8HP trans swap?
Posted: Sun Feb 10, 2019 5:46 pm
by rjsdotorg
I had heard a suggestion of stuffing a complete pair of Hemi and 8spd trans in, but what about just the trans?
The 8HP is well-regarded, and I've driven a 2016 RAM1500 a bit so I do like it.
https://en.wikipedia.org/wiki/ZF_8HP_transmission
It also isn't really any more expensive than a well-built A-727 or 47RH.
There are a lot of trans adapters out there with bellhousing and crank parts included, but, I have not seen one for the 360/413 RB to ZF8HP.
I'd be perfectly happy with just the paddle shift method.
Anyone heard of such a beast?
Re: ZF 8HP trans swap?
Posted: Mon Feb 11, 2019 12:04 pm
Sounds like a big project either way. I think that a complete engine and tranny with complete harness and computer would be the way to go here. I would prefer to use a 6.4 Hemi out of a heavy duty truck once they start showing up in wrecking yards.
Posted: Mon Feb 11, 2019 12:06 pm
Do the later (4.7 or hemi) enignes still use the old LA bell housing bolt pattern?
If so there is an adapter kit for the A518 to the 440. The A500/518 did not have the B/RB bellhousing but used the LA bell.
http://smrtrans.tripod.com/smrtransmiss ... o/id9.html
Posted: Mon Feb 11, 2019 3:31 pm
by rjsdotorg
I don't know what the patterns are; I'd seen their site as well.
Iwa also looking at
http://shop.destroked.com/index.php?rou ... ry&path=35
It's likely the newer 8Hp uses an SAE pattern
