Board index » Maintenance » Drivetrain
Travco/Dodge add a turbo..
Unread postby frank-id on Mon Jan 28, 2013 9:35 pm
Doing a bit of research to put a turbo on my big Dodge engine. The very common Ford/Int. 7.3l engine is 444 cu in. Turbos are available. I have a Ford 7.3l with a turbo and the truck runs good. I am also gonna add some alcohol/water injection and experiment with adding LPG. Frank
frank-id
Re: Travco/Dodge add a turbo..
Unread postby Acesneights on Mon Jan 28, 2013 10:10 pm
Cool, A fellow diesel enthusiast. 7.3 is a good engine. I assume it's an IDI right ?
I want to do a Cummins with an Allison but gotta find the right combo.
Unread postby TheAutoArchaeologist on Thu Apr 04, 2013 10:24 pm
Dodge put Turbos on 440's in the late 70's. I found one a year back in a Foretraveler... which owned/bought out Travco.
Unread postby frank-id on Thu Apr 04, 2013 10:32 pm
Please post any/more info. I have been trying to make decisions about adding the turbo. Thanks, Frank
frank-id
Unread postby rcb on Sun Apr 07, 2013 8:13 pm
and on these, turbo lag wouldn't really be a concern... so remote mount wouldn't be so problematic... if you wanted to go that way. Even small amounts of boost could help a fair amount, without the need of dropping compression.
rcb
Travco Model: Looking for 210
Unread postby TheAutoArchaeologist on Mon Apr 08, 2013 10:49 pm
I just googled "Dodge 440 Turbo" and it comes up with some pictures and info.
Return to Drivetrain
