Rear end dope
Posted: Sat Aug 27, 2016 10:15 am
by Jessecommonman
Hello! I have a 1969 track that I been restoring just finished all new brakes, wheel cylinders brake lines. I want to drain an replace the differential dope in the rear end can somebody tell me what I need to use ?
Re: Rear end dope
Posted: Sat Aug 27, 2016 10:16 am
by Jessecommonman
I'm sorry TRAVCO.
Re: Rear end dope
Posted: Sat Aug 27, 2016 3:05 pm
A standard 80w90 gear oli should be good.
Re: Rear end dope
Posted: Sat Aug 27, 2016 4:23 pm
by Jessecommonman
Thanks so much for the info.
Re: Rear end dope
Posted: Sun Aug 28, 2016 7:45 am
by Fellchase
Verify if your diff is limited slip...mine was. If limited slip you need to pour in the additive with the 90w. Good luck.
