Travco Wiper Blades
Travco Wiper Blades
This will be a Sticky for Part#s\nAny Part#'s you find that work post here.\n\nWiper Blades:\nAnco 52-20 . \nProbably not gonna find them at places like Advance etc. I bought mine form a Heavy Truck Parts place. Napa might be able to get them.
- Travco Model: 1975 320
Re: Part#'s
I'll add to that the Anco refill # is 53-20.\nI bought the refills first, but they wouldn't fit my blades. It turns out the blades were Trico, and are a narrower blade by about 1/8". But the 52-20 blade fit the Trico arms using the u-shaped Trico adapter that comes with the 52-20 blades.
1975 Travco 320
Travco Water pump
Water pump-Napa TFW 42040\nIt will not have a cross flange but a round one and in my opinion is a cheap chinese copy. Hvae you old one rebuilt if you can or try a Hi Per one from Summit maybe. I was not impressed with the quality and the impeller was smaller than original but if you are broke down on the road somewhere and need a waterpump, that is the number\nAlso as Per 77 Travco Adanvce sells GMB 120-1200.
Travco Radiator Hoses
Radiator hoses-\nNow this is for my 1975 270/440 \nNapa Upper NBH 7634 (cut to fit but lines up perfect even with a/c)\nNapa Lower NBH 7711
Travco Steering Box Stub Shaft Seal
Part number for Steering box stub shaft seal-\nAdvanced Auto-Powercraft 7095\nThese commonly need replacement after the lash on the steering box has been messed with. No need to replace the entire box for one seal. it's a bit tricky but it can be done without removing the box.
Travco Dash Board Air Conditioning Vents
Dash Air conditioning vents. Bear in mind I have a 75. I think mid 75 was the dash change but I have the later model one.\nhttp://www.nostalgicairparts.com/air-condition ... et-755.php
Travco 270 Front Brake Lines
Travco Front Brake lines for DISC only. I looked and both my 74 220 and my 75 270 had the same rubber fornt brake lines. \nSee pic for NAPA part #.
Travco Rear Springs
Rear Springs for the 270 have to be special ordered. Any Spring shop can order them from Triangle spring but bend over.\nIt's gonna hurt. Around 500$/stack\nPart# 34-139 for rears.\nLead time is about 2-3 weeks to be custom made but the spec is still in thier system.\nIt is not wise to add leaves to 40 yr old springs. The main leaf cracks and your in big trouble...
Travco tie rod end part numbers etc.
Here are some part #s for Travco's\n\nSteering Box cardone 27-7501\nSteering link Ds881\nTie rods Es2082r and Es2083l
Travco Headers Small Block
Hedman Street Hedders #79016 long pipe for motorhomes 318 -- 360
