Does anyone know Weight of Travco 290
- Travco Model: 1966 Dodge Travco
Does anyone know how much their Travco 290 is?
Re: Does anyone know Weight of Travco 290
What year is it? Look for a metal tag that list a GVWR rating, etc... it should be located up front inside the radiator access door.
It is a 1966... Can't seem to find metal tag with GVWR rating.
I don't think they made a 290 in 1966... I bet it's a 270. Can you post up a picture?
- Travco Model: 1968 & 1965 Travco 270
if it is a 290 it should be 15,000 I think Jim
1968 dodge travco 270 in The work's
just my $.02 worth.. if unit is driveable, I would take it to a truck stop \nand weigh it. you will get a printout and then... no bs....\n you will be sure of the weight... \nbelieve the cost is under $10.00 FWIW\nBTW: Post a pic and members can positively identify the size/model you have\nBBB
