45" Dipstick Replacement Part?
Unread postby simimiller on Wed Sep 27, 2017 7:43 pm
Anyone know where I can get a replacement dipstick that's 45" long for my 220 (RM350)?
simimiller
Travco Model: 220
Re: 45" Dipstick Replacement Part?
Unread postby badbillybiker on Sat Sep 30, 2017 5:38 am
Hmmm... if you can braze, get a old? speedometer cable, get a used transmission dip stick top and make your own...
or,,, I belieVe you have a 3128? ...junk yards should still have a lot of those engines........
FWIW.
Unread postby simimiller on Sat Sep 30, 2017 10:41 am
Thanks. I'm also considering using a shorter dipstick. There is a break in the line that is connected with a rubber hose and could shorten the run.
simimiller
Travco Model: 220
Unread postby KB2CRK on Sun Oct 01, 2017 11:04 am
I also have a rubber hose in the dipstick tube. I wonder if Travco had to make them longer.
Unread postby badbillybiker on Sun Oct 01, 2017 5:53 pm
I had my "broken" dipstick repaired as the end of the dipstick kept missing the other end
on the engine due to separation...and a new rubber piece of connective hose installed.fixed the problem
The reason for the connective hose in the middle of the dipstick tube?
Because it is solidly mounted at the very top end near the radiator.. and on the oil pan.
The rubber tube allows for engine movement and if the tube was one piece the whole length,
it would break with the first engine torking taking off from a dead stop!
JMO
FWIW
HTH
Unread postby Franknsr on Thu Oct 05, 2017 11:09 am
A dodge Cummins dipstick is 44.5" long if that helps.
Franknsr
Travco Model: 270... I think
Unread postby simimiller on Mon Oct 30, 2017 5:01 pm
badbillybiker wrote:Hmmm... if you can braze, get a old? speedometer cable, get a used transmission dip stick top and make your own...
FWIW.
All good suggestions! Thanks very much. Also to everyone who responded. Very helpful - I'll let you know how it turns out. Taking her out this weekend and don't want to burn up!
simimiller
Travco Model: 220
Return to Engines
