In need of turn signal switch
- Travco Model: 77 Dodge Travco 320
I'm unable to keep my right turn signal on and am searching for a replacement switch or ideas for using from another vehicle. Is there a rebuild kit for the steering gear? I have no power steering whatsoever and am not familiar how this hydro boost system operates. Thanks in advance.
- Travco Model: 1972 Starcraft Starcruiser
Re: In need of turn signal switch
I believe the turn signal switch is a basic item most napa stores should be able to get it. it is a pain to get to as you have to pull the steering wheel. but I would take it to napa and see if they can locate it.
first I have to ask did your chassis not come equipped with power steering or is it not hooked up?
If its not equipped you will have to locate a pump two lines and a replacement gear box. all this can be done with a little research.
if its not hooked up do the following.
- I would imagine you or someone has removed the belt for one reason or another (most likely a leak).
I would start by replacing the belt.
Then top off your pumps reservoir.
Turn on the motor and turn the wheel back and forth (from stop to stop) a few times this will fill the system. do this a few times then check the level in the resistor topping off as needed.
This is also a good time to look for leaks. Most common is from the input shaft seal. This can be fixed with gear box in place!
Never half ass two things at once. \nWhole ass one thing.
