tire fitment and brake help for 69 2+2
- Travco Model: 1969 M375
I have a 1969 Travco 29' on the M375 chassis in decent shape I am remodeling. Fridge,AC still work and i am 80% done with water and kitchen. I am starting on tires and brakes. My tire size is 7.5x17 tubed split rim. The only tire I have found,(2 in front) are Michelin XC A and cost me 474.00 per tire with tube and liner. Is there a decent Bias replacement out there for the other 5 tires I need? I also am trying to fix driveline band brake and redo brake system. Can anyone help with finding parts for 14 inch drums and the hydraulic boost system? Your forum helped with alternate P300 parts search for front shoes but it appears my rear brakes are 14 1/8" x 3" and I can't find.
Please advise: brake help for 69 2+2/270 M375 chassis
Okay I found my tires.Goodyear high milers from simpletire. spent $1,300 on 5. I am still looking for help on brakes front and rear I have her up on jack stands and I'm about to try to release star wheel to remove drums. does anyone know where to find replacement brake shoes? I am about to try to have them relined if they are in good enough condition to do so
Re: tire fitment and brake help for 69 2+2
Your best bet may be to get your shoes relined. There are others on here that have gotten shoes for the 69 270 (2+2 and 270 are the same except for trim and door location) but I can't help you there. I have a 76 2+2 on the M500 chassis .
